Can my SCH-R730 support a larger battery?
crickal
I feel like the 1500mah of my R730 Cricket Transfix not holding charge for the heavy usage. I bought an original battery 5 months ago but it is practically end up with swelling! About to have a go on a 3rd party 2500mah battery out off mpj. Can my phone support a battery larger than stock?
The phone can electrically support any size battery, the only difference is that the larger the capacity of the battery, the longer it takes to charge it. The question is whether the battery supplier has a larger back to replace the one on your phone, so that the back will fit with the larger battery installed.
You can always get 10,000mA (and larger) external batteries that plug into the microUSB port.
