I just noticed my phone wouldn't turn on, so I took out the battery and tried it and the AT&T logo appeared, but then it just went to black and it won't react to anything. Can anyone offer help?
Did you try to put a custom boot animation on it? Mine did the same thing when I did it :argh:
If that's the case, you can delete the boot animation and it'll fix it right up (if you're like me, you'll have to do it through busybox).
Took me forever to figure that out, since for some reason it wouldn't let me change permissions or remove with ADB directly :s:
If not, though, you can try to do a factory reset (that was the first thing I tried, and all it did was wipe my data (I mean, how could it boot with me having messed up the boot animation? )):
Turn off the phone
Press and hold Volume + and Power buttons
Use the Volume - key to navigate down to "wipe data/factory reset" and hit Power
