Help Can someone please help?!
Ok, so I've been attempting to root my breakout for a little while, and I finally figured it out, or so I thought. Actually I got to the final step in which you download the zip file from your sd card, but when I try to do so, an error comes up saying installation aborted or something like that. Can somebody help me with this problem, I almost understand everything about how to root it but this error keeps coming up. I have a feeling it might have to do with the transfer of the zip file to my sd card because that is the only part I don't really understand.
First you need to copy BreakoutRoot.zip to your phone's SD card. Then, in CWM Recovery, you need to choose the "Install ZIP from SD card" option and select BreakoutRoot.zip when it asks which ZIP to install. Are you saying that you're getting an error at this point?
I never ran into this issue when flashing the rooting zip. However, CWM usually gives some lines of diagnostic information before saying "Installation aborted." Do you see these lines? Or, better yet, can you post a picture of your phone's screen when this happens?
I cant take a picture but i will show you exactly what it says when i flash the zip.
"-- Installing: /sdcard/breakoutroot.zip
Finding update pakage...
Opening update pakage...
E:Can,t open /sdcard/breakoutroot.zip
(bad)
Istallation aborted."
Based on the output, it's not even getting a chance to extract and run the updater-script within the ZIP file. Otherwise, the first lines that you'd see would say the following, as you can see from the calls to ui_print():
[HIGH]
ui_print("================================================");
ui_print("= =");
ui_print("= Root for Pantech Breakout =");
ui_print("= =");
ui_print("= By: mtmichaelson =");
ui_print("= =");
[/HIGH]
I suggest you redownload BreakoutRoot.zip, verify its MD5, and then copy it to your sdcard again. The size of the ZIP file is 631,645 bytes. Its MD5 is 38A080D267BF24081D6CB5541EB9510A
You can check the MD5 of your downloaded BreakoutRoot.zip using the following web script (or any other MD5 checker): Encrypt MD5 hash online
If the MD5 is correct, and it still won't flash, ensure that you're running ClockworkMod recovery and not the stock recovery.
