Can stop metro from seeing my data usage?
Status
Not open for further replies.
dboypipes
When I rooted my lg motion somehow metro stop knowing/seeing how much data I was using, when I called them they told me 0mb. But my phone ran 3g. Now I have the Kyocera hydro witch I just rooted but they still see the amount of data I use n it seems to be a lot. Can lucky patcher somehow block my data or is there some other way to stop them from seeing my data n slowing me down as soon as I go over 500mb?
Your motion was running on 3G which didn't count against your highspeed data limit. Your Hydro is probably running on HSPA or LTE which is counting against your data limit. Any data you send through the network is counted against your data limit there's nothing you can do on the user side to stop that.
How about you either get on a plan with more (or unlimited) data, or stop trying to steal? Because that's basically what you're trying to do.
Status
