can you give me an advice as beginner ?
Hi, I am new in this forum and new in developing android apps, I have already start coding with kotlin but a lot of times when my code don't work I cant find what is the problem.
I think that I didn't start android programming right or I have skip some steps or I don't know.
I like if someone help and give me a write path to follow
thank you
Hi. Why did you choose Kotlin? There are many more resources out there for learning Android programming with Java.
See the sticky posts at the top of this forum for some useful information.
If you have specific questions, feel free to ask here.
I really like to learn kotlin because I find it simple but the probleme is how to fixe errors code in android studio
My point is, if you are struggling, then choosing a lesser used language is going to make it even tougher for you.
yes I really see that, one of the probleme is this:
can you please tell me what is the problem ?
Sorry I can't help because I don't know the Kotlin language, or its libraries.
Actually, what type is 'dd'? The type 'var' doesn't really say anything because it's a generic type. That's one of the advantages of Java being a strongly typed language, because you always know what you're dealing with.
