Help Cannot access home wifi, and cannot delete saved connection
Tina Kiz
Recently changed router security from WSP to WEP. Cannot delete old remembered connection from my setting on the Samsung Transform, and when I add a new one with WEP password info, it keeps saying "out of range". I am well within range as it is in next room and am using it with my laptop now. Havent had wifi at home in almost a week. But when I am away, the WIFI works at other locations and will let me set up new ones. Just want to delete old connection and create new one.
Your best bet honestly is to revert your wifi settings to WSP, connect your Transform to your wifi, then try to make it 'forget' the access point, disconnect your Transform from the wifi, and then edit the settins again to WEP security and try to reconnect to your Transform, if it doesn't work you may want to keep your wifi settings off WEP... I keep my wifi open because I made sure the wifi I bought would only broadcast through my house and not to my neighbors.
