Hello all,
I have been using the super one click method to root my HTC Magic Saphhire 32A.
It works well so far albeit need to alter some SU files in the program. Running of terminal emulator with the command prompt SU confirmed that I have the superuser rights.
Now the problem is whenever I use ROM manager to reboot in recovery, the phone restart, HTC logo shows, then the next screen I see is a big asterisk and a phone image, after this I pressed Home + power, the screen manage to switch to Android system recovery utility, BUT with only 3 options:
1) Reboot system now
2) Apply sdcard:update.zip
3) Wipe data/factory reset
And in the end of the screen, there is one line highlighted in red: E: can
