Root Can't enter recovery mode: it just shows a battery icon
mojuba
Trying to root my device in order to upgrade to newer Android versions, however, I'm stuck on the very first step of rooting:
I can't enter the recovery mode! My tab just shows a big battery icon after restarting. The tab is charged 95-100%. Restarting again boots the OS and everything is normal again.
I tried two methods: (1) VolumeUP+Power and (2) the `adb reboot fastboot` command on my Mac, both had the same effect: after the restart the tab shows the battery and nothing happens.
Any idea why this is? Or is it normal? But then how do I get to the recovery options (in order to eventually root the device)? Thanks!
