Help Cant fix my "twlauncher" error problem...help!
hi all:
First off I am a newbie to a lot of this phone stuff so if answers could be as simplistic as possible that would be great. Okay, with that all said here I go.
I have the Samsung Mesmerize(SCH-I500) from US Cellular. I wanted to root it as soon as I learned what that was. I was successful using the Superoneclick. From there I learned a little bit more and wanted to change my boot animation. I tried and tried with no luck what so ever. I then learned that you need to have a kernel I think that is capable to chaning the boot animation. This is the part where things went wrong and you have proly heard it a thousand times. I read incorrectly and got the kernel for I-9000 and screwed mu phone up so it would not load up at all. I did some reading and learned how to get the EE19 stock setup on the phone using ODIN. I was successful there but I am getting the twlauncher error now. I did some more reading and tried the Kies from Samsung and get the same result either way. I also try to download apps and it says I have no room on the phone. Can you tell me a step by step process to get the phone back to 100% working stock while keeping my phone number on it. I have tried everything. Heck, I would even try non stock if it all works perfect.
I was able to get the phone working thanks to the VERY TIMELY EC09 release that just came out. It took a couple tries on ODIN but on the th try it worked out just fine and there are no more hickups on the phone now luckily. Now to get this all rooted again
EC09 is an older release that EE19. Can you verify the build that you have?
Would it be EH09? If so, that would still not be the latest release that I am aware of. EH09 was a leaked release that is available on XDA.
The official build that is available on the USCC site, as of 29 August 2011, is EH17.
