Apps Can't fix this Text View problem
GodLovesYou
What's up!
I am doing a project that consists on import from storage a .csv file, but I had a problem after I upload the excel.
I have a textview that will shows me the search of what I want, but I cant understand why this is happen.
This is the code:
Java:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="fill_parent"
    android:layout_height="wrap_content"
    android:orientation="vertical" >
    <LinearLayout
        android:layout_height="match_parent"
        android:orientation="horizontal">
    <EditText
        android:id="@+id/etSearch"
        android:layout_height="wrap_content">
    </EditText>
    </LinearLayout>
    <LinearLayout
        android:id="@+id/lvh"
        android:background="#ffe6e6e6"
        android:weightSum="3" >
        <TextView
            android:id="@+id/txtproductcompany"
            android:layout_width="0dp"
            android:layout_weight="1"
            android:gravity="left"
            android:text="COMPANY"
            android:textColor="#000000"
            android:textSize="13sp" />
        <TextView
            android:id="@+id/txtproductname"
            android:padding="3dp"
            android:text="PRODUCT"
        <TextView
            android:id="@+id/txtproductprice"
            android:text="PRICE"
    </LinearLayout>
</RelativeLayout>
The problem is the print that I have taken. Basicly this is multiplying Textview's
Which view is this layout for? Is it for your Listview?
I will explain...
I have two xml layout's and they are exacly the same but the one that I've posted here is the result layout and where I want to add in the top a Textview that will help me search.
