My phone is now somehow stuck. When I power it on it goes into that black menu where I can select:
- reboot system now
- reboot to bootloader
- apply update from ADB
- apply update from SD card
- wipe data factory reset
- wipe cache partition
- mount system
- view recovery logs
- power off
And no matter what I do, I cant get anything to work. If I try to wipe data and do factory reset it gives me following error:
E:format_volume: make ext4 failed on /dev/block/bootdevice/by-name/userdata with 1 (I/O error), data wipe failed.
- reboot system now
- mount system
- power off
