Can't make calls after flight
  • Start date Start date
A
Android Question
Guest
I have had a problem multiple times on my Android phone that after coming back from a trip abroad, it appears the phone can't access the network. When I switch on the phone after landing the name of my operator is not listed in my status bar. Instead I see "Emergency calls only" and get a "Restricted Access Changed" error message.
I can't make or take calls, can't send text messages, but WIFI still works. Sometimes it can take over 24 hours before I get the service back. This is really irritating. Another strange observation is that this only happens after the return trip to my country. Not after the outward trip.
I usually try things like restarting the phone, opening it up to eject and insert the SIM card and so on, but that never works. After a random amount of time the phone just starts working normally again and I will not have any issues until my next trip abroad.
I have searched the net and not found anyone else with a similar problem. Do you have any suggestions?
Thanks!
Hi and Welcome
I suggest you call your network operator about that problem. You could also resister on the forums and re post your question in the forum for your particular phone to see if anyone else has the problem.
Roger
