That button does also show the cap status. When it is white, it means cap mode. But check the white icon carefully, please.Thanks but to be more specific the caps stay on visually but when you are typing they type in lower case like you normally would. Its more of a visual thing.
Ok, I know what you mean. I am not myself aware of any Android keyboard that imitates this (there may be one, but I've not met it).Thanks but to be more specific the caps stay on visually but when you are typing they type in lower case like you normally would. Its more of a visual thing.
Thanks James and I see what you are saying but I cannot get my phone to mirror that so I can't tell if that would fix it. How did you get that? Thanks everyone for the post comments, for me its just easier to see the caps - as simple as that. Thank you.That button does also show the cap status. When it is white, it means cap mode. But compare the different white icon carefully, please.
The white icon with a underline means 'cap keeping' mode while the normal white icon means 'cap once' mode.
Do you get what I mean above?
I shared two screenshots on amazon cloud just now. https://goo.gl/R1tNh1
Just check those two files, Cap keeps - 0.png & Cap keeps - 1.png.
