Help Captive Potal Detection for Samsung Products
ksabo
Hi all,
Designing a NAC for work and I am having trouble getting Samsung devices to recognize the user must sign in to a captive portal for network access. I have managed to find the URLs that other products use for captive portal detection (i.e. captive.apple.com for iOS, and most Androids use clients3.google.com/generate_204). In fact, every device I have tested (apple, motorola, older samsungs, lg, nexus) seems to present the user with a pop up stating they need to log in to the WiFi. Newer Samsung devices (confirmed on Galaxy Note S5 and Galaxy S7) are not presenting this pop up. I think Samsung has butchered the Standard that Google created and I am wondering what URL they use for Captive Portal Detection in their newer devices.
Thanks!
Same problem here
when the phone connects, it doesn't do any DNS requests at all on any domain.
It goes directly on the http server hosting the captive portal page, I guess using only the gateway's IP.
It tries 3 times within 3s to get the /generate_204, then once again 1 min later. After that it stops trying until the user goes in the browser. From there everything works as expected.
I haven't seen any behavior like this with any other phone
Any solution is welcome
Hello, I have an issue detected only on samsung s4 and j7 but ok on others (ios, lenovo, asus, huawei)
I installed a webserver with captive portal on a raspberry with a hotspot (nginx/apache2/lighttpd, hostapd, dnsmasq) when i connect to this wifi network a popup "Sign-in to network" is displayed or an auto launch of the captive portal page is done.
This behavior failed only on some samsung smartphone like s4 and j7, when i connect nothing happened!!! no popup nor auto display CP page
any proposition?
