Capture on pc>?
Hi I have a PC TV capture deivce called Easy Cap im using my M8s to play to the tv capture device but it does NOT shoe up on the pc, the box works fine on a Tv but wont seem to work on the Pc.
Any tips or help are most welcome thank you.
I have used the easycap for capturing VHS and it did it no problem.
This thread has gone unanswered now for a few days...
Probably because nobody can understand it. I certainly can't.
Could you rephrase the post with as much detail as you can?
I have a PC which uses a video capture device, which is from USB to RCA it captures video from a VHS player .
I have tried to capture the video output from my Android box .
I want to record the video output on my PC from the Android box via the USB capture device.
Is that clearer?
