Capture+
Playing around with the floating toolbar, today, and tried to access the quick memo function. I get a notification that says I need to install the QMemo+ app.
Click install and nothing happens.
Carrier locked or just another LG function that doesn't work?
I'm pretty sure that Quickmemo came installed on the phone. I checked the application page:Screenshot_20191125-150055.png
Since it can't be uninstalled and it isn't listed in Google Play that mean it came installed. I access it through an icon on a home screen. I just set up the floating toolbar and it works for me. Did you check you App Info in Settings to see if it's on your phone? I use Verizon, could your carrier have removed it?
