Have a look at your wall charger which came with the tab.
Important is the output voltage & amperage, e.g. 5V/2.1A
For this example above: The car charger should have exactly the same voltage (5V) and the same or more amperage (2.1A).
A charger with output 5V will be to find easily because 5V is USB standard and all USB car chargers will have it.
So you have to look at the right amperage
If your tab's wall charger has 9V/1.5A output then the car chargers electrial specs are all right
To the mechanical specs of the car charger: The diameter of its output plug is 2.5mm (and the hole is 0.8mm).
So you should have a look at your wall charger's output plug for its diameter.
