I'm a newbie. I've been cruising with my CliqXt and I'm tired of waiting for 2.1 Figured I would do a little investigating to see what's out there. Thanx for having such a nice place to visit....
Depending on the amperage of the car charger and if you're using every antenna (using nav apps do use quite bit) it is possible for the phones drain to exceed the charger's ability to charge.
