For optimal sound and media flexibility (play flac, better decoding*), you need the Droid.
I've read a lot of complaints about the BT having low sound quality. Is it the bandwidth?
A2DP enables stereo audio with Bluetooth. For control, you need to look into AVRCP, IIRC.Is there a car stereo that can be completely controlled with the Droid?
I've been reading the stereo ads, they don't say much.
What is it that A2DP enables you to do? Is it the way to go?
Depends on who you ask. Sound quality is a highly subjective topic. I mean, there are people that are happy with the poor audio quality of their FM transmitters. There are those that insist on high quality hardwired audio connections. It's impossible to tell where you fall in this spectrum based solely on your posts. BT isn't as good as wired but whether that makes any difference is up to you to determine.How is the sound quality over BT?
If only playing music files on the SD card then USB also provides higher quality.Huh? ANY android device will play music, not just a Droid. And to get the best quality sound, use a 3.5mm headphone cable to your stereo. Using bluetooth or an fm adapter will lose quality.
A2DP certainly is designed for what it does.Yep, bluetooth wasn't meant to transfer live sound, its just a feature that is beingn supported.
