Hey hey, I'm not new to rooting and custom roms, but relatively new to doing so on hammerhead. I went crazy with almost every rom and kernel out there (well at least the popular ones) and finally settled on Carbon. I got all my settings just the way I like them and I was surprised to see the jump in improvement in battery life, customization, well everything... until they "updated" the rom to be built over CM. It was originally built over slim (AOSP), which supports the more popular kernels as well as ART. (CM does not) I know of the CAF patch to get AOSP kernels compatible with CM, but does anyone know if it will also makes CM compatible with ART? I tried the CM build on Carbon, but got all types of bugs, fc's, and entire system shutdowns for no apparent reason. I was on ART, fully knowing that CM doesn't support it. But after experiencing the difference even on stock, I refuse to go back. Any word? If not, I'll just stick to the 8/24 nightly build (the last Carbon Rom AOSP build) which supports ART. Thanks for any help/advice that comes my way! Incidentally, this is not meant as a knock to the Carbon Rom devs and their decision to rebuild it over CM. But as an enthusiast I like to keep my roms updated, and I can't do so with my current settings. (I think they're up to 8/31 build as of this post?) So I'm just a little sad and looking for a workaround.
