Case and Desktop charger
Hi
Can anyone help?
I've ordered the hard case with hole and the desktop charger for my One x - they're out of stock here in the UK apparently, but I had a thought....will the phone fit in the desktop charger/stand with the case on, or will it have to be removed each time it charges or sits on my desk....would be a bit of a PITA if so.
Grateful for any feedback so I can amend my order if necessary
thanks
Alex
If its the case with holes in that you have ordered, then according to the description on the HTC website here, yes the case will work with the dock without removing it. This is the case I have ordered too.
thanks very much! Different form the Galaxy Note case/stand - they do not work together...was very annoying (but not half as annoying as the phone itself)
