Here is a link that explains it:Yes, I would love more details on this method. Thanks. x
And if anybody has any other ideas I'd be interested in those too.![]()
You're right. The control seems to be a checkmark - that won't work unless you have a way of figuring out the status of the setting. (If they used a "switch", I think it would have worked, but not for a checkmark. )One thing that occurs to me is if I use a screen tap option then wont it simply toggle the services on/off every time the event triggers the task? For instance, if I set up a screen tap method every time the phone is unlocked then every other time wouldn't it toggle the services on and ever other time toggle them off? I'm hoping to find a way to ensure that they are always turned on if they have already been turned off for some reason. Maybe I'm just misunderstanding how the screen tap options works?
http://www.pocketables.com/2013/07/how-to-emulate-touch-input-using-tasker-and-root.html
