Widget Locker allows you to put widgets in your lock screen, and some apps can put music controls on the lock screen. Some apps will also let you replace the slider with an iPhone-like slider bar instead of the stock one. Just search "lock screen" and you'll get plenty of hits.
If you have something specific in mind, you can let us know and we can give you a specific app that can do that.
