my dealer used a 2gb card and installed the android os on it and it take sup like1.3gb.. i got an 8gb card how do i transfer everything to that? thanks
"Android OS" lies in the NAND or internal memory which is nicely and safely locked away .You cant install any OS on SD Card (without breaking warranties and Phone beyond reasonable imagination).
SD Card should be blank if it is from legitimate source .
You can use SD card reader and computer to transfer the files but rest assured "Android OS " is safe in your phone .
