ya it would be nice to have a different sound when I plug im my USB to my phone from what plays when I get a text. I love my text sound.... its BAZINGA lol
Firstly are you using the standard text app that is on the Phone?
If you using this then open this up and when you see the list of all the texts that you have recieved press the left hand nav button (the one with four square above it)
select settings
select the nofication ringtone and select the one that you want.
Go back to your homescreen
press teh menu button
scroll down to settings
select sound and display
select notification ringtone and change this.
Hey presto you should have two different tones. One for text and the other when you plug in your usb cable
When your battery's running low I think. I think basically uzee wants is like in windows where you can change sound schemes for all the notifications (startup, shutdown etc)
