Help changing resolution on 2.2
pogiewun
Member
Hello all. I just upgraded to 2.2 and am having trouble trying to figure out how to change the resolution. Everything is so tiny on this monster screen. And is there a way to use the default launcher? Or am I stuck using adw. Not really digging the 2.2 on here so far and want to go back to 2.1 but can't until that recovery link is updated.
You need to edit the build.prop file in /system and change the LCD density from 160 to 140 (or maybe vice versa)
Use root explorer and to edit the file after you mount it as Read Write
build.prop is located here : /system
to reset launcher. Home>parameters>applications>(choose #2)> all apps >adw.launcher then scroll down erase defaut actions
* sorry of the path is approximative, mmy is setted in french !
