Help Changing Vocoder setting
amirkl
Hi,
I got a lot of complaints that my voice sounds muffled on the other side when making calls (to the point that it is not legible, making my phone not usable).
When checking the echo call option in Skype it sounds fine.
From looking at other posts online, a few LG users with a similar problem mentioned that modifying the used Vocoder helped them.
I have tried to modify the Vocoder configuration by looking through the hidden menu (I used the "Secret phone info" app and 3845#*659#, 277634#*# to get to it), But I was not able to find an option to configure it.
Can anyone recommend a way to modify the Vocoder setting in android in general or specifically for LG optimus F3 (MetroPcs)?
I am running a rooted version of the MetroPcs Optimus F3.
Thanks,
Amir
