Help Changing Voice Recordings directory
gilroy222
Member
I am not sure why android always sticks the voice recordings in the music folder but it is a very stupid idea, since everytime you listen to your music, and suddenly your voice pops up.
Is there any way to change the default directory of where the recordings are saved on my S5? Or if I simply drag that "recordings" folder to another location on the SD card, will it still save recordings there?
Reason I want to move it is because I use the stock music player, which gives you the option to select which music folders you would like to play from which is good in order to avoid the recordings, but not good when android stuck the recordings right in with the music!
