Changing widget settings?
ExPalm
Member
I just bought Beautiful Widgets for it's compact time/weather widget, (gained another row of icons on home screen)
When you first create a widget with this, there are many configuration options, but it appears the only way to change something is to delete the old widget and create another one. Is this true, or is there a way to edit the options for an existing widget?
EDIT: Found the answer in another forum. Tap the weather icon. then menu.
(I'd delete this, but I can't find an option to delete my post.)
