Help Changing widgets in daily briefing
goalc
Member
Is there a way to change the APN News widget in the daily briefing ? I want to change it to the BBC News but as this is our first smartphone I am not sure if this is possible or not?
Any advice is much appreciated.
Hi,
this is what i did:
1) get rid of daily briefing.
2) install bbc news app from market.
3) install bbc news widget on a home screen of your choice.
I then installed weather bug and put the widget for that app on the same home screen as the bbc news widget.
It works so much better than daily briefing and it has the information I want!
Hope this helps as a suggestion...
Hi,
this is what i did:
Thanks for that :)
