charge and power issues
  • Start date Start date
A
Android Question
Guest
My Samsung galaxy ace stopped charging, I plugged it in over night and it still failed too charge, it has now died and will not take charge, I have tried many different chargers but too no avail, please could you advise me on what the problem could be?
Hello, and Welcome to AF!
For your charging problem ill suggest you to try the following one by one till you solve your problem:
1- Clean your Device USB port.
2- Try a new or different battery.
If none of the above worked, then i would say your USB port is damage and needs repair, even though it doesn't look damage from the outside.
Good luck!
