Help Charger Port not working.
bunraku
Hi
Since Friday my USB-C charging port has stopped working.
Some of the time it will charge when off and some of the time it won't.
Even a couple of times it has when on, but when i unplug it and put the charger back in nothing.
I have cleaned it with
Toothpick(Plastic).
Toothbrush
Denture stick with the bristles that goes between the gaps in your teeth.
Compressed air
And as a last resort contact cleaning fluid
And still the same.
I've also done a factory reset in case it was an app that was the issue.
I thought it might be the pins, but they look ok as in as much as i can see them.
Any idea if anything else i can do?
Thanks
You should also try a different cable to rule that out as an issue. If this does not help you will need to get the port repaired or send back under warranty/insurance.
In the short term you could purchase a cheap wireless charger from Amazon as your phone also support this.
