Charger problem
tommyldo
Hello,
My charger sometimes charge fast, sometimes slow, but lately its usually slow. I used other charger several times and it's charging fast all the time.
My question: Why my charger sometimes charge slower ? How I can fix it ?
Thanks.
What smartphone are you charging and what charger are you using?
These kind of details are quite important to find a solution to a problem like this.
Hello,
Thanks.
If the other charger is OK and charging it fast, sounds like you got a duff charger. And the fix is to replace it.
Hello,
Thanks.
It may depend on the connection cable (inflection, refraction, etc.). Detachable cable or integrated?
It's very hard to answer to you. Charging system is the most annoying theme in android. In three diffrent mobiles I had problems with charging, and I always have solved the problem in three diffrent directions.In my opinion you shouldleave this problem to repairmen)
