Help Charging LED Slowly Pulsating
smg65
Member
As usual, I'm probably way over thinking this and there probably isn't a problem. Maybe the charging LED on my VZ LG G2 has been pulsating since day one and I simply haven't noticed it. For some reason, I had thought it had glowed a solid orange when charging. Maybe I'm thinking that because that's what my previous phone did while charging. This morning is the first I've noticed it (or more likely paid attention to it). I'm using the LG charger that came with the phone. Battery life has been absolutely phenomenal! 50-60 plus hours with fairly heavy use (no videos though) with 15-25% left over! Looking at it charging right now, it's been charging about 1/2 hour, and it's gone from 18% and is currently at 45%. I would consider that pretty fast! Also... everything seems to work just fine.
OK... perhaps I should just shut up and go back to sleep????! Anyway... I thank you in advance for holding back your laughter until I'm out of sight! But if you do feel any pity for me, to say "the pulsating orange light is normal" would be appreciated! If it isn't, then I guess I go back into "worry mode". :o
Steve
Steve
Yes it has always done that. Mine does it too. Your phone is fine.
Ha ha! Thanks! Don't know why I'm like that! I just like to find things to worry about I guess. Loving the phone!
