Help Charging my TF101. AND typing lag.
kylesnav
Just got my TF and i love it! 2 concerns, first being how do i charge the eeepad? is it possile to charge the dock and the pad at the same time? secondly i am noticing a extreme amount of lag when typing with the keyboard on a webpage. I can not keep track of grammer just because the lagwhen tyoing is bad with or without keyboard dock. I am fully up dated.
ah i reset the tf and it kind of helped. do you think it is a speed issue? sometimes it speeds up and works well. most times. not so much..
so there is no keyboard lag when i use polaris office or anything else really. and it seems when i turn off the trackpad that helps a bit. Using firefox kind of helped but it isnt optimized for tabs! it always loads the mobile page. and the images render at a relly low quality.
o
Use dolphin HD and set it to desktop mode.
kylesnav. Re-Charging. I charge my Pad when connected to the Keyboard Dock.
This will give a full charge to both the Pad & Dock.
Suggest you download the excellent Free Dual Battery App which displays the level of both batteries.
