Charging Problem
Hey guys,
Had my S6 Edge now for just under a year and when I'm charging the plug is getting very, very hot to the point where it's just cutting out the charge altogether. Anyone else experiencing this or have any solutions? It's very frustrating.
Thanks, Chris.
I'd try to not use it. It sounds like a fire waiting to happen. It's most likely defective and should be replaced.
Yeah I'm gonna contact Samsung, it's just about within 12 months old so surely they should replace it. I've ordered one from eBay but I don't think it'll be genuine tbh.
Update - since i've been using the non-fast charger it's been fine. It takes a hell of a lot longer to charge, but it doesn't heat up so it must have been a faulty charger.
Maybe your charger is not compatible with the voltage in your country. Mostly chargers are multi-voltage compatible with an input 100v - 240v but yours may be different.
