Check Battery Cover issue: Solved
Ed Derz
I recently started having the issue of having to "check the battery cover" on my S5 every 5 minutes. There is so much on the WEB about this, but no "definitive" answer. I tried the following and for the past 3 days have not seen the warning.
I removed the back cover and the micro SD card. I cleaned the memory card contacts with a soft eraser and reinserted, then cleaned the back cover with a damp cloth, and where the silicon gasket contacts the back of the phone. After putting it back together and restarting, things seemed "normal"
The issue came back and no amount of cleaning seemed to help. I found a thread elsewhere which seemed to resolve the issue- Hopefully for good this time.,
This applies to people who have a Samsung wireless charging back cover. If you remove that, there are 5 metal contacts that do not exist in the standard cover. Place a small piece of masking take over the upper 2 contacts nearest the camera, then replace the cover. I confirmed this does not impact the charging function. I also looked for a replacement back cover assuming that was bad and found that there are 3rd party covers which only have the lower 3 contacts, so that gave me additional confidence in this fix.
