Choetech Charge battery 2.0
gisac001
Compared to other chargers, this Choetech has all ports equal, no difference of amperage and devices can be connected to any port without worrying amperage; it automatically detects the correct one.
You know that others have ports with 1A (smartphone and iphone, etc.) And other with 2.1 / 2.4A, the latter suitable for tablet (iPad, etc ..).
So you have to choose the appropriate available port before connecting to load; You can connect 5 ipad, which is impossible on other shippers multiport.
And 'well it has done and pleasant to the touch, as if covered with a velvety film. It 'very light and compact, weighing more cable unit and is designed to take it back on the road and it costs less than most other equipment sold.
The packaging, though plain on the outside, is well done, with rubber mounts inside to avoid shocks.
You can take a look at the features here
http://amzn.to/1GyjGgc
