chompsms timestamp problem,switched to Handcent BUT....
So after reinstalling chompsms twice, the timestamp out of order doesn't disappear so I'm using Handcent in the meantime.
Handcent is good but I don't like how when you're adding a contact in "To" field, the number shows. Is there any way I can enable the contact NAME to show up in the To: field?
Btw, I'm on Android 2.1
Mine is showing the name and number ok.
After you make the selection?
When I press the + sign, it shows name and number when I search. After selection, it shows:
To: 131034554
You're right after selection it shows the number only. It shows the name and number if you start typing the name and it pops it up to be chosen.
