Choosing MetroPCS phone
zzyzzyzzx
i have limited funds, and can only afford one of the metro phones that are 150$ (before or after mail in) im looking at
Huawei Premia 4G
ZTE Avid 4G
LG Motion 4G
ZTE Anthem 4G
basicly the cheaper 4g phones, im really not sure what to go with (i really want an S3 but its not in my future) i would like your opinions on which would be the best to go with
While it ia true.that they will open up tmobile gsm phones soon, the promo for the three 4g phones at $29 lasta til June 30. Starting the 12 gsm phones will be allowed on metro but it ia.unknown when the new phones will come in. the galaxy exhibit 4g and the lg optimua L9 domt really have.a.due.date but those will come to metro. The galaxy exhibit is like a rebranded galaxy.s3.
As of June 12, you can bring any phone you want to Metro, if you can find something you like that you can afford, and they will support, go ahead and do that.
If not, I highly suggest the LG Motion of the 4 phones you listed. The screen size is a turn off for some, but it really isn't bad. It is a nice, fast little phone and battery life isn't all that bad. There is a bit of development behind it as well if you are into that. It is the best phone I've had on Metro thus far. :)
On June 12, 2013, MetroPCS will begin offering products and services using T-Mobile's GSM and "4G" HSPA+ wireless networks. And 4G will be in 'turned on" in Connecticut on the 19th.
Better wait until then :)
sources-http://en.wikipedia.org/wiki/Metropcs
thanks for the info, as i did not get much info before hand i bought the avid, the mic sucks, but other then that i love it, i needed a phone quick status for work, hopefully im going to be getting the S3 or S4 soon
