Help Circles battery widget malfunction
My battery widget went from turning red to orange (when it hit 15%) and now just stays blue even when it goes under 10%. Anyone have any ideas how to fix?
I'm guessing here. What about force stopping the circles app and rebooting?
Have you installed any apps that might interact with the circles or battery widget?
I tried force stopping Circle config and the Circles app and reboot. It seemed to work. Suddenly the battery circle was red--I was down to 5%. It's charging now so I'll have to wait until it's drained again to see if the fix is permanent. The Circle config app hasn't seemed to come back on after reboot. The force stop button is dark and the only option now is disable. Hmmmm. Weird. But thanks for the response
But the Circles widget is working and on the home screen, right? I wouldn't worry about the app manager for Circle config. It probably won't go active until you try to go into the settings for the circle widget (which you access by flipping the battery circle).
Yep it's working. Right now anyway
