plbelanger
Looking for some testers
Clipboard admin is a clipboard manager for Android. The application runs in the background saving all copied text into an SQL DB for later viewing and/or modification. A system tray icon is enabled for easy access while also displaying your most recent entry.
Features:
- Sort via alpha, oldest, newest, modified date
- Create and sort by favorites
- Export to SD
- Share
- Edit/delete clipping
- Copy existing clippings
- Add custom clippings
- Delete entire db in one go
- Backup/restore db
https://play.google.com/store/apps/...WZmeWRlbHVzaW9ucy5hcHAuY2xpcGJvYXJkYWRtaW4iXQ..
Features:
- Export to SD
- Share
- Backup/restore db
