Hello again ayush! It has been a while! What I did:
copied the ROM onto my SD card
powered off phone
booted into CWM recovery
wipe data/factory reset
wipe cache partition
wipe dalvik cache
install zip from sd card
reboot
Is that correct?
thanks again ayush29! I now have a wonderful operating system on my phone!You missed the most important step, no wonder your rom is unstable.
You need to go into mounts and storage and format /system, /cache and /data before flashing the zip file. Wipe sd-ext also if you have an ext partition on your sd card.
Without this step you might left some files from the previous rom in the new system and which are now causing you problems.
