AtomicStryker
Hi, i'm having a problem with the CM 12.1 ROM on my Moto X Play. When using the same setup of Tasker+Secure Settings that worked fine on stock, i cannot set or clear the lockscreen PIN in CM 12.1.
Secure Settings has root access, is enabled under device administrators and system+ reports as "ok".
However, when i execute a set PIN / clear password task like i did under the stock ROM, nothing happens. The lock remains as last set by CM.
Is there some other way i could do this, via console commands or such? Google failed me, or i didn't input the proper questions.
