BigGuyWhoKills
I flashed Cyanogen Mod 10 to my Exhibit II, and most things worked, but the phone was not one of those things. So I Nandroid'd back to RebelRom in order to get a working device. Will someone look over my steps and tell me if I used the wrong file or installed the files in the wrong order? Here is the sequence of files that I installed (all via ClockWorkMod recovery v5.5.0.4b):
1. CM10 (cm-10-20121126-UNOFFICIAL-ancora_tmo.zip)
2. Gapps (gapps-jb-20121212-signed.zip, I also have gapps-jb-20121011-signed.zip, but I did not use the one dated 2012-10-11)
3. Quick Flash (Quickflash for JB4.1 v6.2a.zip)
4. Gapps (Step1-jb-4.2_roms_only_gapps-v2.zip)
5. JusTunBean Aroma (Step2-JusTunBean_aroma.v6.2.zip)
At this point (after step 5), the device worked fairly well, but I had neither "phone" nor "contacts" apps.
Between steps 2 and 3, the AOSP keyboard kept crashing, preventing me from signing into my Google account. I side-loaded a 4.2 keyboard APK which got me going, but Google login manager (or something similar) would crash right after I signed into my account.
I did NOT do a full wipe before step 1 because I was lazy and overly-optimistic. Before I start over with a full wipe prior to step 1, I want to be certain that I am installing the correct files in the correct order.
Is CM10 a 4.1.x or a 4.2.x rom?
Thank you for your time.
