please anyone knows what flash player is compatible with my samsung galaxy y s5360??
because adobe flash player is not compatible with my handset...please send me links of flash player for my handset
None because hardware is too weak. Trying to force install other flash players may or may not work, and it will be laggy and crashing at times. Basically, cheap phones=no flash.
I'm fairly certain flash media is playable without issue on our cheap phones with the right know-how. Too bad those who know how wont take the time to share. I'm also certain its not as easy as being directed to the right app to download and install, its going to be a complicated and daunting process. While waiting for the right developer to show you the way, feel free to check out this link:
There is a section named - 'Android Flash Player versions' under which you will find the earlier versions. The file will be downloaded as an .apk (Android Package) file. Save it to your external SD card. Then install the file on your phone from your SD card.
