Compatible Screen Replacement Huawei GRA-L09
Guest13
Hope someone could help me, a friend gave a phone to me for replacing the screen, I've never done one before with the screen glued in place, I've managed to remove the screen and ready for the new screen to be placed in.
I have no idea of Huawei phone models, as the screen is broken I'm unable to look in settings, about phone section to find any info. On the back casing it says Model GRA-L09, so I went on ebay and found some screens and all of them says its for the P8 Huawei GRA-L09 Ul00. Would this screen fit on my phone? because mine says GRA-L09 does that mean it's a P8?
Thank you for any advice you can give me.
Thanks, the model is GRA-L09, I'm unsure what network he was on, might be 3uk or Tesco mobile, all i want is a new screen. How many variants of that model is there?
I suggest that you should replace the battery at the same time. It will save you from having to remove the screen again. This is an old model so the battery might have lost a lot of its capacity.
Thanks this has had quite a good bang as smashed the glass on the back casing too, I've ordered one of those now, I measured my phone, the dimensions are same as the P8 and not the light version so ordered the LCD and back glass covering, not sure yet if it'll work but screen lights up with half the screen black, other half is rainbow colors. The interior components seems intact, I'll think about a new battery if I get it up and running, it is a good idea to replace the battery, thank you.
If your phone is not unibody like my HTC, you'll only need to open to caseback to replace the battery.
Anyways because you are already at it, it's preferable to replace the battery at the same time.
Whrn you try to see if it work dont put the lcd or back on fully do a teat so in xase you need to replace the battery after testing yoy can replace it
Thank you everyone for your help, it is quite easy to remove back case to change battery, I'll only change that part if necessary, phone works with new screen. Thank you again.
