Apps compound controls
jelly
I am having trouble with extending layouts if anyone has a idea what im doing wrong i would appreciate it.
_______________________________________
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android: orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<EditText
android:id="@+id/editText"
android:layout_height="wrap_content"
></EditText>
<Button
android:id="@+id/clearButton"
android:text="Clear"
></Button>
<TextView
android:id="@+id/textView"
android:text="@string/hello"
</LinearLayout>
__________________________________________
package com.paad.reset2;
import android.app.Activity;
import android.os.Bundle;
public class reset2 extends Activity {
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
import android.content.Context;
import android.view.LayoutInflater;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.LinearLayout;
public class ClearableEditText extends LinearLayout {
EditText editText;
Button clearButton;
public ClearableEditText(Context context) {
super(context);
// Get a reference to the LayoutInflater Service
String infService = Context.LAYOUT_INFLATER_SERVICE;
LayoutInflater li = (LayoutInflater)getContext().getSystemService(infService);
// Inflate the view from the layout resource
li.inflate(R.layout.main, this, true);
// Get references to the child controls
editText = (EditText)findViewById(R.id.editText);
clearButton = (Button)findViewById(R.id.clearButton);
// Hook up the functionality
hookupButton();
private void hookupButton() {
clearButton.setOnClickListener(new Button.OnClickListener() {
public void onClick(View v) {
editText.setText("");
