Conference call question
s_wall98
Hey guys, I'm about to drop my HTC Rezound and trying to decide on the HTC One, S4 or G2. Besides the reports of the phone being fragile and Verizon screwing with the buttons I'm leaning G2 but had a quick question.
I have to do quite a bit of conference calling for work and need help with the following scenario.
I call person A then place them on hold and add person B. When person B picks up I merge the calls. Is there any way to end the call with person A and keep person B on the line?
I know with my rezound I cannot, the only way to hang up on person A is to end both calls.
Thanks guys.
I havent used the phone to make a 3 way call so I would just be guessing
but as I understand it .... it works like this:
call A on the line.... press 'add call' and dial a second number
now you have 2 lines going simultaneously but seperate.... you can press the 'swap' button to switch between A and B.... or you can press the 'merge' button to make it a conference call
this is the point where trial and error will have to teach you......... once they are 'merged' is there a "split" button of some type to seperate them back to seperate lines......... if theres no way to split them then the only way to hang up on A is to also hang up on B
if you can split them then you can toggle to A and end that call...... then it should automatically toggle you to B
so the key here is can you split them once theyre merged....... youll have to try one and find out
Thanks guys.
Person A is sometimes automated which is what causes the problem...can't tell them to hang up.
Like I said my Rezound well only let me hang up on person 2. I thought all phones might be like this but I've seen a couple people complaining about it with that phone.
Who knows, maybe I'll catch a sales rep with a G2 and have them try it.
