Help Connecting an andriod box to a video sender!
Ryd67
My video sender is connected to my Sky box via a scart lead. I am looking to purchase an android box but I need to know if I can connect the box to the sender via AV output using a scart adaptor and phono leads.
Can anyone help?
Might be able to. Although SCART being older is analogue, and Android devices tend to favour HDMI digital video connection. So you'd likely have to get hold of a HDMI to SCART converter or adapter.
Thanks for the info. Not too bothered about it being hd. I just need to use sender so I can watch TV in bedroom. The cable would have to be 3.5 jack to phono into scart adaptor which would then go to sender. The mx pro has a av output with 3.5 to phono cable. Would u recommend this device.
